Can anyone make a suggestion for a stand that will hold both laptop & hercules rmx or would I be better off to get two stands?
geposted Mon 09 Jun 08 @ 10:46 pm
have you thought about custom designing and fabricating your own stand with a little care will look professional enough and probably work out cheaper than shop bought stuff. if you don't want to attempt it yourself seek out the help of a blacksmith or metal shop, hope that's given you food for thought...
geposted Tue 10 Jun 08 @ 3:47 am
Hi, I've been using the Instand CR3 with the sideKick combo. It works great with the laptop and RMX. It's completely free standing so you won't have to worry about making space on the dj table for the RMX and laptop. You can find the Instand at:
http://www.instand.com/CR3/cr3.html
geposted Tue 10 Jun 08 @ 10:59 am
that looks like a good option, vailixi.
geposted Tue 10 Jun 08 @ 11:48 am
I like the InsTand... just gotta find something a little cheaper for right now. It's a bit more (since the stand and sidekick together are about $190) than I was wanting to spend to start out. but it's given me food for thought.
geposted Tue 10 Jun 08 @ 6:25 pm
