i lost the software that came with my Virtual dj console with the serial nu,ber on it. if i buy the pro version of virtual dj would i still be able to use the mk2 console? i registered my serial number on virtual dj is there a way where i can get the number to use to upgrade to the pro edition?
geposted Tue 10 Jun 08 @ 7:24 pm
Just visit the Download Center - http://www.virtualdj.com/update.html
Use your forum password to login. From there you can download your software and retrieve your serial number.
geposted Tue 10 Jun 08 @ 9:33 pm
