Hey Guys,
When I mix using the cross faders it causes a scratching noise...which is quite irritating when everything is spot on but the scratching noise comes through!
Any ideas how to fix this?
Thanks
Thanks
geposted Wed 11 Jun 08 @ 2:45 am
It could be because you have the setting to high on your config menu. When i up mine to much my laptop can't handle it and makes a scratching noise when trying to use the crossfader.
geposted Wed 11 Jun 08 @ 12:06 pm
Probably it's that. Maybe first try to put your latency to "auto" and see if that helps it :)
geposted Wed 11 Jun 08 @ 1:15 pm
thanks - will look into that.
cheers.
cheers.
geposted Fri 13 Jun 08 @ 6:51 am
funnily enough this actually turned out to be the skin I am using..If I change the skin the scraching sound goes if I change it back it comes back...weird!! skin: mix station SV 04
geposted Sat 14 Jun 08 @ 5:18 am
