Hey guys,
Does anyone get these small black triangles on the screen when using a Mac? I don't know if it is a bug or something wrong with the graphics?
Someone let me know.
Thanks,
DJ Jazzy Jetta
Thanks,
DJ Jazzy Jetta
geposted Wed 11 Jun 08 @ 12:26 pm
Could u post screenshot here. Thanks.
geposted Wed 11 Jun 08 @ 1:44 pm
It's not just you, i get the same thing from time to time. Plus the little "keylock" and "timecode" buttons that are attached to the jogwheel on the skin often don't look lit up until you pass the cursor over them.
geposted Wed 11 Jun 08 @ 9:21 pm
It's probably a problem with the refresh rate with the skin. What skins are you guys using?
geposted Wed 11 Jun 08 @ 9:36 pm
Yes. On what skin?
geposted Wed 11 Jun 08 @ 11:16 pm
I'm using Virtual Vinyl and I use the Widescreen audio skin.
geposted Wed 11 Jun 08 @ 11:21 pm
Dizzy can u try if the problem persist if u use other skin. Thanks.
Where exactly is this small black triangle appeared on the skin? It be better if u can post a screenshot of that too;)
geposted Thu 12 Jun 08 @ 7:23 am
Here's a screenshot. The small black triangles are not really a big deal. What I find annoying is the timecode buttons on the jogwheel are often half there. Btw, you'll see the black triangle just to the right of the right-hand side level meter.
geposted Sat 14 Jun 08 @ 11:45 am
