hi!i just want to know if i can use HERCULES RMX to VIRTUAL DJ version 3.2?this is what i use before i have the HERCULES RMX.I install the one that comes with the HERCULES but the features of the VDJ is limited.If i can use the HERCULES RMX with VDJ version 3.2, can anyone please teach me how to make the HERCULES work with VDJ version 3.2?
geposted Wed 11 Jun 08 @ 3:26 pm
What are the limitations you're referring with the LE software that comes with the RMX? Maybe I can help, if there are features you're looking for that you can't find.
If you were a licenced user of Virtual D.J., you would be able to upgrade to the most current version of VDJ (5.1), which works extremely well with the RMX. The fact that you're this far behind regarding current software, and the fact that your user name is followed by "no licence user" makes me think that you've got an illegal copy of the software, version 3.2. If that's the case, I don't think you'll find any help here.
geposted Wed 11 Jun 08 @ 11:11 pm
The software that comes with my RMX is VIRTUALDJ 5 DJC.The limitations are that there's no AUTOMIX, cannot change the skin, etc.
is upgrading to PRO is FREE?I'm trying the PRO version now for a limited time only.
PLEASE HELP!THANKS
PLEASE HELP!THANKS
geposted Thu 12 Jun 08 @ 1:28 am
Ah, you're correct about the limitations in the DJC Edition.
Upgrading from the DJC Edition to 5.1 isn't free, but heavily discounted, and well worth it. Have a look here:
http://www.virtualdj.com/forums/87892/General_Discussion/_NEWS__Special_PRO_version_discount_price_for_Hercules_DJConsole_RMX_home_users.html?page=1
However, if you're a licenced user (meaning it's a LEGAL copy that you own) of 3.2, you should be able to use the licence for 3.2 to upgrade free.
geposted Thu 12 Jun 08 @ 2:46 am
can any one tell me how to let the RMX playing automatically from A to B without hiting anything on the PC or the console.
thx
thx
geposted Thu 12 Jun 08 @ 9:41 am
Hi There! just want to ask cause i'm planning to buy a laptop and i also want to install my HERCULES RMX in there and in the future i want to upgrade to PRO also.
my question is: do i need to upgrade the laptop and my desktop also, and i will be paying twice?
and is there anyway that i don't have to change the setting of the GAIN and EQ's everytime i change the song on the same deck?cause everytime i change the song for example in DECK A, i have to reset the GAIN and the EQ's.
PLEASE HELP!!!!
PLEASE HELP!!!!
geposted Mon 16 Jun 08 @ 2:27 am
