Does anyone on here use the Vestax VCI 100? I am getting one and wanted to see if anyone else on here uses it and how well it works with this software. I want to do video and it would be nice to not have to carry around all that equipment run the software when you could just plug this in. I know you need a soundcard with it as well.
I heard there is a midi map from Virtual DJ for the VCI 100. Is this true?
geposted Wed 11 Jun 08 @ 3:27 pm
The VCI is natively supported in VDJ, all the functions work as they are labelled on the controller.
It works impressively, but one thing I dislike is the outter rim of the jogwheel, which is designed to work as "pitch bend" not "nudge", which takes time to get used to, I much prefer the way the CDJ's work, for me this is a semi-major problem, other than that the unit is pretty flawless.
You can use the general midi map in VDJ, which of course will allow you to customise the buttons, but the downside is you lose some of the lights.
I imagine there will be a proper VCI-100 mapper developed soon.
geposted Wed 11 Jun 08 @ 5:36 pm
Awesome. Good to hear. When are they expecting a midi map update?
geposted Wed 11 Jun 08 @ 5:54 pm
