Forum: Old versions
Topic: Glitch on play (brief moment of previously played audio) under certain condition
There's a glitch (50-100 ms of old audio) when play is pressed under certain conditions:
If master tempo is set to advanced and enabled on the deck and you play track, then stop it and start playing again after either simply going back to the begin of the song using stop button where there is silence (use track with silence in beginning, try different tracks if you don't get it immediately). Or (may not be heard so easily) by turning the platter ccw and then pressing play again.
Obviously not driver/hw issue since turning of the master tempo removes the glitch. Setup vdj 5.1, vista 64,dx, safemode /overclock setting had no effect on this.
geposted Wed 11 Jun 08 @ 5:17 pm
