hi there,
im new to these forums although i have been into virtual dj for a while..
bought 2 cdj 400s a little while ago and am struggling to get them to work with virtual dj.
the problem seems to be with the asio sound driver: every time i try to change something in the config it comes up with a message saying there are not enough channels.
the decks are going straight into the computer. ive downloaded the driver from pioneer, the decks are installed properly on my comp and when i play a track on vdj it goes through the decks, mixer and out the speakers.
ive also clicked enable for midi under the remote control section as well...
anyone got any idea what my problem might be/how i could solve it?
thanks
thanks
geposted Thu 12 Jun 08 @ 1:09 am
What settings have you got in the "soundcard" setup tab in VDJ?
geposted Sat 14 Jun 08 @ 2:58 am
the ASIO driver is selected
geposted Sun 15 Jun 08 @ 12:36 am
