i try to scan the hard drive for bpms and it makes it halfway thru ,then it crashes. this is the report i get. Date/Time: 2008-06-12 13:59:05.220 -0700
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: Cue_LE
Path: /Users/test/Desktop/Cue_LE.app/Contents/MacOS/Cue_LE
Parent: WindowServer [89]
Version: ??? (1.0)
PID: 290
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000004c
Thread 0 Crashed:
0 com.atomixproductions.cue_le 0x00007fdc CLabel::SetText(char*) + 156
1 com.atomixproductions.cue_le 0x0000b888 CListView::ResetSearch() + 140
2 com.atomixproductions.cue_le 0x0000b8dc CListView::NewSearch() + 68
3 com.atomixproductions.cue_le 0x000911f4 CSearchDB::Refresh() + 68
4 com.atomixproductions.cue_le 0x0009124c CSearchDB::OnScanHD() + 44
5 com.atomixproductions.cue_le 0x0004d760 CTree::OnRightClick(TTreeItem*, tagPOINT*) + 1152
6 com.atomixproductions.cue_le 0x0004e1bc CTree::OnMouseDown(int, int, int) + 872
7 com.atomixproductions.cue_le 0x0000c9d4 CMain::WndProc(OpaqueWindowPtr*, unsigned, int, int) + 556
8 com.atomixproductions.cue_le 0x00051a0c MacToWindowEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 548
9 com.apple.HIToolbox 0x9329a934 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
10 com.apple.HIToolbox 0x9329a08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
11 com.apple.HIToolbox 0x932a0e90 SendEventToEventTarget + 40
12 com.apple.HIToolbox 0x9332d230 HandleMouseEventForWindow(OpaqueWindowPtr*, OpaqueEventRef*, unsigned short) + 236
13 com.apple.HIToolbox 0x934903e8 HandleMouseEvent(OpaqueEventRef*) + 368
14 com.apple.HIToolbox 0x932a11fc ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 496
15 com.apple.HIToolbox 0x9329ab84 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284
16 com.apple.HIToolbox 0x9329a08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
17 com.apple.HIToolbox 0x932a0e90 SendEventToEventTarget + 40
18 com.apple.HIToolbox 0x932e1c04 ToolboxEventDispatcher + 92
19 com.apple.HIToolbox 0x932e1b90 HLTBEventDispatcher + 16
20 com.apple.HIToolbox 0x932e0148 RunApplicationEventLoop + 148
21 com.atomixproductions.cue_le 0x000517a4 main + 964
22 com.atomixproductions.cue_le 0x0000316c _start + 760
23 com.atomixproductions.cue_le 0x00002e70 start + 48
Thread 1:
0 libSystem.B.dylib 0x9004a6e8 syscall_thread_switch + 8
1 com.apple.Foundation 0x92bfc52c +[NSThread sleepUntilDate:] + 152
2 com.apple.AppKit 0x9381caf0 -[NSUIHeartBeat _heartBeatThread:] + 1100
3 com.apple.Foundation 0x92be40c0 forkThreadForFunction + 108
4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x900411f8 mach_wait_until + 8
1 libSystem.B.dylib 0x90040fc4 nanosleep + 388
2 libSystem.B.dylib 0x90044798 usleep + 88
3 com.numark.usb2.hal 0x0541c2a0 PGOSXDevice::threadRun() + 452
4 com.numark.usb2.hal 0x0540d374 OSXUserThread::entry(void*) + 44
5 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 3:
0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000b29c mach_msg + 60
2 com.apple.CoreFoundation 0x907ddad8 __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907dd3dc CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x91458524 HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x914582c4 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 4:
0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
2 ...ple.CoreServices.CarbonCore 0x90bf83f4 TSWaitOnSemaphoreCommon + 176
3 ...ickTimeComponents.component 0x98f97440 ReadSchedulerThreadEntryPoint + 436
Thread 5:
2 com.apple.audio.midi.CoreMIDI 0x96f2aac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.midi.CoreMIDI 0x96f1dc80 MIDIInPortThread::Run() + 64
4 com.apple.audio.midi.CoreMIDI 0x96f21f44 XThread::RunHelper(void*) + 28
5 com.apple.audio.midi.CoreMIDI 0x96f2b87c CAPThread::Entry(CAPThread*) + 96
Thread 6:
0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8
1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480
2 com.apple.audio.midi.CoreMIDI 0x96f2aeb4 CAGuard::Wait() + 88
3 com.apple.audio.midi.CoreMIDI 0x96f2249c Task::Run() + 404
Thread 0 crashed with PPC Thread State 64:
srr0: 0x0000000000007fdc srr1: 0x000000000200f030 vrsave: 0x0000000000000000
cr: 0x24028224 xer: 0x0000000000000004 lr: 0x0000000000007fd0 ctr: 0x00000000900015c8
r0: 0x0000000000007fd0 r1: 0x00000000bffccd70 r2: 0x0000000000000000 r3: 0x00000000011a95f0
r4: 0x0000000000000000 r5: 0x00000000bffccd44 r6: 0x00000000ffffffff r7: 0x0000000000000006
r8: 0x0000000000000006 r9: 0x0000000000000000 r10: 0x0000000001200b57 r11: 0x00000000a0b8b740
r12: 0x00000000900015c8 r13: 0x0000000000000003 r14: 0x0000000000000000 r15: 0x00000000a329a698
r16: 0x0000000007b012e0 r17: 0x00000000bffff590 r18: 0x000000006d6f7573 r19: 0x0000000000000001
r20: 0x0000000001178470 r21: 0x00000000ffffd96e r22: 0x0000000000000000 r23: 0x00000000bffff6f0
r24: 0x00000000bffff428 r25: 0x00000000004bbd4c r26: 0x0000000000429358 r27: 0x000000000118cb70
r28: 0x00000000004292e0 r29: 0x00000000004293d0 r30: 0x0000000000400000 r31: 0x00000000004bc0d0
Binary Images Description:
0x1000 - 0x2f5fff com.atomixproductions.cue_le ??? (1.0) /Users/test/Desktop/Cue_LE.app/Contents/MacOS/Cue_LE
0x5cf000 - 0x5d1fff libogg.0.dylib /usr/lib/libogg.0.dylib
0x5da000 - 0x5dcfff com.hercules.hosapiframework 1.0 /Library/Frameworks/hosapi.framework/Versions/A/hosapi
0x705000 - 0x75afff libmp3lame.0.dylib /usr/lib/libmp3lame.0.dylib
0x795000 - 0x7b6fff com.hercules.hdjsapi 1.0 /Library/Frameworks/hdjsapi.framework/Versions/A/hdjsapi
0x1298000 - 0x1299fff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x540c000 - 0x542dfff com.numark.usb2.hal ??? (1.3.3) /Library/Audio/Plug-Ins/HAL/NumarkUSB2AudioHAL.plugin/Contents/MacOS/NumarkUSB2AudioHAL
0x54b7000 - 0x54fafff com.apple.QuickTimeFireWireDV.component 7.0.1 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x5708000 - 0x5771fff com.apple.AppleIntermediateCodec 1.0.1 (124) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x5786000 - 0x57fffff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x63e8000 - 0x6421fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x7c05000 - 0x7ce5fff com.apple.audio.codecs.Components 1.4.7 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x70000000 - 0x700fdfff com.apple.audio.units.Components 1.4.7 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90894fff com.apple.CoreFoundation 6.4.8 (368.31) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908dd000 - 0x908ddfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908df000 - 0x909e1fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3b000 - 0x90abffff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90ae9000 - 0x90b5bfff com.apple.framework.IOKit 1.4.1 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b71000 - 0x90b83fff libauto.dylib /usr/lib/libauto.dylib
0x90b8a000 - 0x90e61fff com.apple.CoreServices.CarbonCore 681.17 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec7000 - 0x90f47fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f91000 - 0x90fd3fff com.apple.CFNetwork 129.22 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe8000 - 0x91000fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91010000 - 0x91091fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d7000 - 0x91100fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91111000 - 0x9111ffff libz.1.dylib /usr/lib/libz.1.dylib
0x91122000 - 0x912ddfff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dc000 - 0x913e5fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ec000 - 0x913f4fff libbsm.dylib /usr/lib/libbsm.dylib
0x913f8000 - 0x91420fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91433000 - 0x9143efff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91443000 - 0x914befff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fb000 - 0x914fbfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fd000 - 0x91535fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91550000 - 0x91622fff com.apple.ColorSync 4.4.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91675000 - 0x91706fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174d000 - 0x91804fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91841000 - 0x9189ffff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918ce000 - 0x918effff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91903000 - 0x91928fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193b000 - 0x9197dfff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x91999000 - 0x919adfff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bb000 - 0x91a01fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a18000 - 0x91adffff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2d000 - 0x91b42fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b47000 - 0x91b65fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6b000 - 0x91c22fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c71000 - 0x91c75fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c77000 - 0x91ce1fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce6000 - 0x91d23fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91d2a000 - 0x91d44fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d49000 - 0x91d4cfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d4e000 - 0x91e2cfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e4c000 - 0x91e4cfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e4e000 - 0x91f33fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f3b000 - 0x91f5afff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fc6000 - 0x92034fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9203f000 - 0x920d4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920ee000 - 0x92676fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926a9000 - 0x929d4fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a04000 - 0x92af2fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92af5000 - 0x92b7dfff com.apple.DesktopServices 1.3.6 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bbe000 - 0x92de9fff com.apple.Foundation 6.4.9 (567.36) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f16000 - 0x92f34fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f3f000 - 0x92f99fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fb7000 - 0x92fb7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fb9000 - 0x92fcdfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92fe5000 - 0x92ff5fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93001000 - 0x93016fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93028000 - 0x930affff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930c3000 - 0x930cefff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930d8000 - 0x93105fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9311f000 - 0x9312efff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9313a000 - 0x931a0fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931d1000 - 0x93220fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9324e000 - 0x9326bfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9327d000 - 0x9328afff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93293000 - 0x935a1fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x936f1000 - 0x936fdfff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93775000 - 0x93775fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93777000 - 0x93daafff com.apple.AppKit 6.4.9 (824.44) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94137000 - 0x941a9fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x941e2000 - 0x942a7fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x942fa000 - 0x942fafff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x942fc000 - 0x944bcfff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94506000 - 0x94543fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9454b000 - 0x9459bfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945a4000 - 0x945b8fff com.apple.CoreVideo 1.4 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94763000 - 0x94772fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x9477a000 - 0x94787fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x947cd000 - 0x947e6fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x947ed000 - 0x94a4ffff com.apple.QuickTime 7.0.1 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94b22000 - 0x94b41fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96054000 - 0x960c5fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x962f1000 - 0x9632afff com.apple.QTKit 1.0.1 /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x96384000 - 0x963b6fff com.apple.PDFKit 1.0.4 /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x96f1d000 - 0x96f5cfff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x97ad8000 - 0x97ae5fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x985f9000 - 0x986cafff com.apple.QuartzComposer 1.2.6 (32.25) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x98747000 - 0x98747fff com.apple.quartzframework 1.0 /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x98f85000 - 0x99717fff com.apple.QuickTimeComponents.component 7.0.1 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x99966000 - 0x99969fff com.apple.QuickTimeH264.component 7.0.1 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x99b42000 - 0x99be4fff com.apple.QuickTimeMPEG4.component 7.0.1 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
Model: PowerBook6,8, BootROM 4.9.0f0, 1 processors, PowerPC G4 (1.5), 1.5 GHz, 1.25 GB
Graphics: GeForce FX Go5200, GeForce FX Go5200, AGP, 64 MB
Memory Module: DIMM0/BUILT-IN, 256 MB, built-in, built-in
Memory Module: DIMM1/J31, 1 GB, DDR SDRAM, PC2700U-25330
AirPort: AirPort Extreme, 405.1 (3.90.34.0.p18)
Modem: Jump, V.92, Version 1.0
Bluetooth: Version 1.9.5f4, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Parallel ATA Device: MATSHITACD-RW CW-8123
Parallel ATA Device: Hitachi HTS541060G9AT00, 55.89 GB
USB Device: USB2.0Hub, Up to 480 Mb/sec, 500 mA
USB Device: TotalTrack Control, Numark, Up to 12 Mb/sec, 500 mA
USB Device: Numark USB Audio Device, Numark, Up to 480 Mb/sec, 500 mA
USB Device: FreeAgentDesktop, Seagate, Up to 480 Mb/sec, 500 mA
USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA
USB Device: Apple Internal Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
thanks in advance for any input.
Report Version: 4
Command: Cue_LE
Version: ??? (1.0)
PID: 290
Thread: 0
Thread 0 Crashed:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
geposted Thu 12 Jun 08 @ 4:09 pm
What format are your files?
geposted Sat 14 Jun 08 @ 4:42 pm
