Im running the latest iMac 24" with the nVidia 512 card. The machine has a mini-dvi port and I have the adapter to convert the signal to composite or svideo. It works fine in OSX but its not supported and doesnt work in bootcamp.
Anyone have experience with this and how to get the video signal to my plasmas? Is there a device that will scale the mini-dvi to TV?
I would use the Mac version of Virtual but there are too many quirks...see my other post for the list...
http://www.virtualdj.com/forums/90629/MAC_Version_Technical_Support/Review_of_my_first_3_gigs_with_the_Mac_Version___its_Quirks.html
Any help would be awesome......Thanks!
geposted Fri 13 Jun 08 @ 6:28 pm
Do you have this update?
http://www.apple.com/downloads/macosx/apple/application_updates/bootcampupdate21forwindowsxp.html
I used it and it fixed the issue I had with a blue film on my output screen. Maybe it can solve the issue you have.
geposted Fri 13 Jun 08 @ 6:45 pm
Yes I have the update but thanks. Its stated that the mini dvi to composite adapter is not supported in Bootcamp and supposedly hasnt been since 1.1
http://docs.info.apple.com/article.html?artnum=304170
geposted Fri 13 Jun 08 @ 7:08 pm
The only work around is to buy a scan converter. This is a piece of hardware that converts the dvi output of the mac into a composite video or svideo signal. One of these adapters is about $80.
geposted Sun 15 Jun 08 @ 3:07 pm
Do you know of one? maybe a link or product name? Thanks!
geposted Sun 15 Jun 08 @ 7:16 pm
