i read that vdj 5.1 has the ablity to turn the video on and off using the ch faders! how do i enable this?
i have a korg zero 4 so i midi map the channel faders to control vdjs channel faders but all it does is control the volumes?!?!?
geposted Fri 13 Jun 08 @ 7:30 pm
Hi, if you've midi mapped the faders on the mixer to the faders on VDJ, it should work.
Have you checked that you've enabled the option in the VDJ config? It's under the "video" tab, and it's an option called something like "fade to black on volume faders". You just tick the box and you should be good to go.
If that still doesn't work, then I guess you haven't mapped it quite right. Hope that helps.
geposted Sat 14 Jun 08 @ 2:29 am
