Afer a reset to the system, the enter key (default keyboard shortcut) loads the unplaying deck from the browser when pressed. I want a key on my midi controller to do the same thing but cant find the function in the shortcuts. It is NOT
(1) Load filepath
(2) Load from playlist
(3) Load from sidelist
(4) Play
Any ideas what shortcut I need to assign to get it to behave like the enter key on the keyboard?
(1) Load filepath
(4) Play
geposted Sat 14 Jun 08 @ 10:30 pm
Does anyone know the answer to this or know where I can find it? What shortcut do you guys use to load the track from the browser onto the deck?
geposted Sun 15 Jun 08 @ 4:13 pm
browser_open
And you can make macros too, if you add several shortcut functions to one key/midi... lets say, load and play... load and goto cue 1 etc
geposted Sun 15 Jun 08 @ 7:37 pm
Wicked - thanks heaps. I should have looked closer at the descriptions - doh!!
Just programming my new DJM700 to work with video using the midi functions - stoked!!
geposted Sun 15 Jun 08 @ 10:43 pm
