Hi!
I want to test my FS2 with VDJ but i get only one output.
i have only: SCRATCHAMP000 but i missing SCRATCHAMP001
is osx missing a driver or is this a bug on vdj?
I use: OS-X Tiger 10.4.11 on a Intel Macbook Pro
thx
thx
geposted Mon 16 Jun 08 @ 3:03 pm
hi again!
i tested now deckadance software and therefore i has also only the scratchamp000 device but i can but each output for each channel.
DECK A: OUtput 1+2
DECK B: Output 3+4
on VDJ i has also the Scratchamp Device but DECK A + B comes out on Output 1+2
i hope you understand my problem
thx
p.s. so the problem is not on osx - its on VDJ
DECK A: OUtput 1+2
DECK B: Output 3+4
thx
geposted Mon 16 Jun 08 @ 4:49 pm
Hi trace, which version u using? If u own the software, do register at ur modify ur page n grab the latest updates. Thanks.
U can use it with VDJ.
Regards.
Regards.
geposted Mon 16 Jun 08 @ 11:11 pm
