Forum: Old versions
Topic: Search by camelot
Search by camelot in VDJ 5.1 - simple question... How? (camelot search option is missing) In VDJ 5.07 it was working...
geposted Wed 18 Jun 08 @ 4:54 pm
Make sure the Key field is checked as a search field. It will use both Key and Camelot fields when searching.
Yes, in 5.07. But not in 5.1.
Camelot wasn't introduced until version 5.1.
VirtualDJ 5.1 (01 June 2008)
FAME engine:
- new BPM engine with more accurate detection (with new option: "Allow BPM<80")
- new automatic Key detection
- optional automatic Key-Match
- new auto-gain engine
Well you obviously didn't try it before responding....
Right click on the browser columns and choose to show Camelot as a column
Select the first bullet graphic to the right of the Search box and make sure Key is checked
In the Search box enter 02A
What are your results ?
Key detection wasn't introduced until version 5.1. But database support for key/camelot was working before 5.1 (Key was scanned with Mixmeister and stored in ID3tag)
@cstoll
I have now found where is problem. Camelot search is case sensitive! 02A is working, but 02a not. Any chance to repair this small "bug"? I don't want to hold every time shift key during camelot search.
It's not a 'bug'... and please it's 1 letter with a shift... if anything hit Caps Lock before you type -- 02A
