I've down-loaded the trial version of VDJ and need to know if there is anyway I can split the headphone output on my laptop so I can cue up another track and actively mix the track in while another track is playing through the main headphone output. I've got a new DELL laptop with twin headphone out jacks and the mic output plugged into my stereo. Want to be able to use VDJ like I would with decks and a mixer, but want to be sure VDJ will do what I want it to do before I buy. Apreciate any help.
geposted Thu 19 Jun 08 @ 6:15 am
VDJ support that in the real product. You should definitely buy VDJ, its a very good product. I have been using it for years and development team are listening to what customer wants but also suprises me with new features.
geposted Thu 19 Jun 08 @ 8:39 am
You should be able to do that with the trial version as it is identical to the pro version.
In the third box in sound config, select mono/separated which will give you two mono outputs, one for main one for monitor.
Basically you are spiltting the stereo output in two.
geposted Thu 19 Jun 08 @ 9:53 am
same as rick but with pictures... i love comics lol
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output
hope it helps
gotta get round to making a new version of this i know... to bloody fuzzy
geposted Thu 19 Jun 08 @ 11:38 am
