I noticed that the function "NUDGE" by the skin doesn't work in VDJ 5.1 (I mean by the mouse onto the skin).
I tried it in VDJ 5.0.6 and it works greatly
I write .xml code of the skin that I'm using
######################## Channel 1
<button action="show_pannel" value="1">
<size width="16" height="16"/>
<pos x="278" y="467"/>
<down x="277" y="466"/>
<over x="+0" y="+1024"/>
<selected x="+0" y="+1024"/>
</button>
<button action="show_pannel" value="2">
<pos x="278" y="485"/>
<down x="277" y="484"/>
</button>
<pannel visible="yes" id="1" group="1">
</pannel>
<visual chan="1" pannel="1" type="transparent" source="rotation" factor="-3">
<size width="210" height="209"/>
<pos x="88" y="234"/>
<down x="88" y="234"/>
</visual>
<pannel visible="no" id="2" group="1">
<clipmask x="415" y="1161"/>
</pannel>
<visual chan="1" pannel="2" type="transparent" source="rotation" factor="-3">
<down x="+0" y="+1024"/>
<clipmask x="416" y="1161"/>
</visual>
## Jogwheel - Channel 1
<slider pannel="1" action="jogwheel" orientation="round" chan="1" relative="true" mouse="circ">
<size width="66" height="66"/>
<pos x="161" y="304"/>
<fader>
<pos x="22" y="820" nb="24" nbx="12"/>
</fader>
<clipmask x="22" y="952"/>
</slider>
## Scratch - Channel 1
<scratch chan="1" pannel="2">
<size width="260" height="260"/>
<pos x="70" y="212"/>
<center x="193" y="336"/>
<mousecircle x="193" y="336" r="124"/>
</scratch>
<visual chan="1" pannel="2" type="rotate" source="rotation">
<pos x="160" y="304"/>
<size width="67" height="66"/>
<clipmask x="416" y="1460"/>
<mask x="503" y="1460"/>
</visual>
I hope we can fix it soon
</button>
</button>
</pannel>
</visual>
</pannel>
</visual>
<fader>
</fader>
</slider>
</scratch>
</visual>
geposted Thu 19 Jun 08 @ 7:12 am
I hope you've understood explanation of mine
geposted Fri 20 Jun 08 @ 6:51 am
<logo>
<size width="0" height="17"/>
<pos x="310" y="12"/>
</logo>
and fixit same problem a-trakt skin
</logo>
geposted Mon 23 Jun 08 @ 6:12 am
Your answer doesn't fix my issue.
I know xml file needs logo instruction but that I wrote was a part of whole xml file; I related only that to identify where is the only problem in xml
geposted Mon 23 Jun 08 @ 6:24 am
I'll try to explain better what I noticed:
with this skin
http://www.virtualdj.com/addons/skin.html?id=2755
After downloading that, push the button NUDGE like showed in the picture (number 1).
Then put the mouse's control onto the black dot (number 2) and pushing the left button of the mouse, move the mouse on the left or on the right.
You can try these actions with version 5.1 and with previous version: you'll surely notice the difference
with this skin
geposted Fri 27 Jun 08 @ 5:15 am
