Forum: Old versions
Topic: Finding keys of videos
Does virtual Dj do this? Is there a pluggin I use ? If not is there a another program I can scan my vidz for key info? Please help new to video and Vdj all my mp3s are bpm and keyed from before but the programs I used for that wil not work for video Please help!!
geposted Fri 20 Jun 08 @ 12:01 pm
the new version does ID the keycode of the music videos...ver 5.1..also it does the keycode of songs without having to use other applications to ID them.
I must of missed something how do you get it to scan the key or does the key have to be already in the track if so what is a good program for keyying video files?
The Key is scanned automatically with all the other parameters (bpm, gain, ...) when
you analyze or load a track to a deck. Tracks you already have analyzed from previous
versions should either be reanalyzed or loaded in the player (played).
Make sure you have a new version 5.1 installed, than right+click on one of the browser's
tabs (title/artist/bpm/...) to display any other track parameters (like Key).
Problem solved was using 5.07 upgraded to 5.1 all is great havent check acuracy yet but :)
