I was wondering if someone on here can help me please
Thanks in advance
1. Does virtual vinyl's ( Cue software ) Play Apple protected files ? AAC files bought from Itunes ... If not which is the best way to go about converting my entire Itunes purchased list in order for Cue to recognize it ?
Please note that I would be playing all the files off my own computer with my apple password.
also
2. Does Virtual Vinyl support/work with the VESTAX VCM-100 Midi controller ? here's the link http://www.vestax.com/v/products/players/vcm-100.html
Thanks in advance
also
geposted Sat 21 Jun 08 @ 3:56 pm
1.a) No. VDJ nor any other software EXCEPT Itunes can play DRM protected iTunes vids.
1.b) There is no software available that can effectively remove DRM from iTunes files. (iTunes plus vids are okay as they are not DRM encoded). Some guys have methods of removing DRM. But since this is "Illegal" by the EULA from iTunes; Most wont talk about it in the forums. You'd have to search the forums and find who has had good luck with this.
2) No. VCI-100 only at this point. (the VCM's big brother)
geposted Sat 21 Jun 08 @ 4:04 pm
Wow . what a drag on both fronts . Thanks alot for the info..
Im not spinning video yet...... just regular mp3's but I assume it's same case ..
thanks again for the info
geposted Sat 21 Jun 08 @ 6:24 pm
