Well, this is a silly question:
the video output window which I drag to an external monitor is very small. how can I resize the window to fit the whole screen? Using VDJ on my PC, I just drag a corner of the video window and that's it. on my macbook pro, the video window does not have the capability of resizing it.
any help?
any help?
geposted Sun 22 Jun 08 @ 3:45 pm
Best way to do it rather than stretching the window:
Settings
Video
Then in the drop down box select the monitor you wish to display fullscreen on.
You can also do this in the PC version rather than stretching the window.
Ross M.
Settings
Video
Ross M.
geposted Fri 27 Jun 08 @ 7:52 am
don't do that, select the correct output in the video tab, and it will be full screen based on the resolution of the second monitor. The setup is the same for both pc and mac.
geposted Fri 27 Jun 08 @ 9:16 am
Cyder, were you saying don't do that to my suggestion or the way he is doing it.
You and I have both said the same thing!
Ross M
Ross M
geposted Mon 30 Jun 08 @ 2:13 pm
