Hi guys, i'm new arround here and i have a problem with my VirtualDj 5 EQs, the problem is the distortion caused by the Bass EQ when i increase it...
I want to know if there's a way to fix this.
I recently bought a Numark Total Control and a Numark DJIO and when i rotate a knoob or a jogwheel even when use the mouse to drag something, i heard a noise on the speakers... Any way to fix this?
Only one more thing, its possible to reprogram the midi tables of virtual dj to my Numark? i would like to make some tweaks...
best regards
bruno silva
best regards
bruno silva
geposted Tue 24 Jun 08 @ 4:20 am
Go to config and prefrences tab i think
Click overlock and safe mode so that theres no check marks in the box (they should be clear)
this should solve your problem
geposted Wed 25 Jun 08 @ 5:46 pm
