Im trying to set up my virtual vinyl 5 to play videos on my tv screen but i can get anything to show up. Is there a place when i can get instructions to set it up.
geposted Tue 24 Jun 08 @ 2:14 pm
Hey there which mac do you own?
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Kind Regards
Simon Bangs
geposted Tue 24 Jun 08 @ 3:42 pm
Model Name: MacBook Pro
Model Identifier: MacBookPro3,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per processor): 4 MB
Memory: 2 GB
Bus Speed: 800 MHz
Boot ROM Version: MBP31.0070.B07
SMC Version: 1.18f2
Serial Number: W873605PYAN
Sudden Motion Sensor:
State: Enabled
geposted Tue 24 Jun 08 @ 5:24 pm
Two choices you can link up via TV with a DVI to SVIDEO adapter or you can link up to a projector using the DVI to VGA connector or a DVI cable if your projector supports this.
Connect the device to the adapter then the adapter to the mac it will set it up automatically.
Then go to system preferences then displays and untick mirror displays.
Then run VV then go to options > Video , choose your TV or projector from the drop down list and tick activate.
Jobs a gooden!
Kind Regards
Simon Bangs
Jobs a gooden!
Kind Regards
Simon Bangs
geposted Wed 25 Jun 08 @ 3:39 am
It works now thanks
geposted Wed 25 Jun 08 @ 2:20 pm
