In VDJ < 5.1 you could set the gain of one song to whatever you wanted (let's say -3dB) and using "Always match" for the gain engine, every other loaded song would use this value as a reference to match. AFAIK, starting with 5.1 this is no longer possible and this is very annoying as some song clip at 0dB and the sound quality suffers. Any workaround, or should I just live with auto-gain disabled ?
geposted Tue 24 Jun 08 @ 5:07 pm
i had this problem also the way i fixed it was to get a program called mp3gain and reprocessed the gain to 85db and this helped me greatly niw when the autogain does it job the file doesnt clip
geposted Wed 25 Jun 08 @ 1:17 pm
