Forum: Old versions
Topic: audio output problem
hi
i'm using the VDJ5beta
and a BCD3000
problem:
can't get any normal audio out of the BCD's master out!
only a loud noise.
settings vary:
or everything out my macbooks soundcard, no headphone use
or master out with noise (left channel), headphones (right channel)
or master out, no noise with left and right separated into mono signals!
BUT, the problem is only with VDJ, my other programs use the bcd as a soundcard perfectly, master out works, no noise
that is crazy sh*t
what is the solution?
geposted Wed 25 Jun 08 @ 3:11 am
Your problems are caused by using an unlicensed old unstable copy of the software.
It will not work properly as it is a beta.
Please if you would like to use this product support it and order a stable copy.
Look forward to you joining us soon!
