I have tried all the recommendations I could find - have tried turning everything off in startup, registry, vdj config adjustments, etc. I still get pops when I enable the video for a 2nd screen (is fine if I leave video properties set to one screen - all pops disappear with three effects running simultaneously plus vid transition with scratching, etc). CPU barely goes over 1/4 to 1/2 on the green bar - 2200 dual cpu, 2gig ram, 8400GS, Vista Business, vdj5.1, conectiv, tcd with cdx. I suspect the video card is maybe not up to it? I will buy a new one if thats what it is. Can anyone confirm or have any other suggestions?
geposted Thu 26 Jun 08 @ 11:04 pm
Do you have the latest conectiv driver as older ones do have serious performance issues on vista.
geposted Fri 27 Jun 08 @ 2:06 am
Yes - latest drivers for conectiv and latest nvidia drivers.
geposted Fri 27 Jun 08 @ 7:38 am
Do you experience issues in Torq?
geposted Fri 27 Jun 08 @ 9:53 am
I would also check your DPC Latency! Download the DPC Latency Checker program and run that. I had a similar situation with my laptop. It worked fine for just audio but when I enabled the video and used an external monitor I would get pops and crackles. Seems some nvidia drivers have Latency issues. Let me know if this is the case with you as well!
geposted Fri 27 Jun 08 @ 12:53 pm
Uninstalled torq a while back but it doesnt have video (or didnt a few months ago far as I know) so I doubt that would have probs as I only have issues when I enable the second monitor in Vista. I will try latency and let you know.
geposted Fri 27 Jun 08 @ 4:27 pm
Latency is ok according to DPC - spikes to about 1000 - just going yellow - absolute max is 1019
Still get occasional pops and clicks with second vid enabled - any suggestions appreciated...
geposted Fri 27 Jun 08 @ 7:02 pm
