when i plug in speakers to MK2 it doesn't hum but when i hook up speakers to OLD dj it does?
geposted Sun 29 Jun 08 @ 11:50 pm
Ground loop....
Its a common thing with electric audio equipment.
Is it a laptop? If so its easy to verify that its a ground loop. Run laptop on batteries and hum is gone.
To eliminate the problem, connect your PC to a different power connection in your house, and even better (Depending on country), get a grounded extention cord, and connect your PC to that.
Last resort is getting a small box, a ground loop elminiator, that they sell cheap at most local radio stores...
geposted Mon 30 Jun 08 @ 1:31 am
I use a small box designed to get rid of the hum in car stereo systems...$10 at Fry's Electronics or Circuit City in the car audio section
geposted Mon 30 Jun 08 @ 5:48 pm
If it is a ground loop, one of these works real nicely.
geposted Mon 30 Jun 08 @ 5:51 pm
yep a ground loop is what you need. Once you get that yuor good, it used to happen to me but not any more.
geposted Wed 02 Jul 08 @ 10:26 pm
