Just ordered the RMX after reading many many positive and lets day indifferent reviews on here, I guess like everything its a case of trial and error.
My question (although it may sound stupid0 is this, RMX comes with VDJ I have VDJ at present although i haven't actually registered the serial so does it matter which serial I register ?? Of course Ill have to fully check the versions as i dont want to lose any features. I just wondered if the VDJ bundle that comes with it is specifically set up for the RMX or Id be better off Registering my (I believe ) latest version?
Oh and on a funny side note i noticed this on the Hercules Website in the product description section for the RMX:
"Make dancing easier by enhancing the bass (the bass provides the tempo for dancing)."
lol I'm sorry but if you cant dance you cant dance !!
I can imagine people running up up to DJ's saying "hey did you enhance the bass just then because all of a sudden I can dance"!!!
geposted Mon 30 Jun 08 @ 8:50 am
Do you have more than one version of Virtual DJ?
The version that comes for free with Hercules RMX is a limited special version, comparable to VirtualDJ Home Editon.
Home Version also have limited access to downloads of effects, skins and updates etc.
If you have also bought VDJ online here, you got the VDJ PRO version, unlimited for all features and all kinds of downloads.
If you do have two versions, both can be registered in your profile, they dont conflict with eachother ;)
http://www.virtualdj.com/fusers/modifuser.html
And regardless, even if you just have the RMX version, you should register, as it will grant you access to downloads, bugfixes etc
geposted Mon 30 Jun 08 @ 9:20 am
