Im using the RMX with LE on my Mac.
I have tried to add on a Cd player to play some CD's I havent ripped yet and can get them to run.
Any Ideas?
Any Ideas?
geposted Thu 03 Jul 08 @ 8:25 am
on the back of the the unit you have two source inputs use these for your cd players and select line, if in the future you want to add decks select phono, now when you want them to be heard use either your left or right source button situated either side on the top of the unit located at the back as you are looking at the rmx
geposted Thu 03 Jul 08 @ 9:07 am
It is on Line for both, and the correct source was selected.
I even tried to 'load' and nothing different happened
geposted Thu 03 Jul 08 @ 11:50 am
You can't "load" songs from your CD-Player like from your HD.
Just press play on your CD and move the fader for this deck up. (after you selected die right input)
Greetings Tanzi
Greetings Tanzi
geposted Sat 05 Jul 08 @ 7:14 pm
