Would Like to have a Tick box in front of each massage to enable me to activate what I need to use for that night at the club, like for instance..
For each Venue set up multiple messages;
Wednesday Beer and Shot specials, Ask the waitress *** Jessy & Janate for details!!!!!
Thrusday Wings & Imported Beer Specials, Ask the Waitress **** Indira & Jenifer for details!!!!!..
Friday Karaoke competition
Lady's Nite Free Martinis from 8pm to 12pm.....and so on....
geposted Fri 03 Aug 12 @ 8:30 pm
Hi SBDJ
after upgrading to version 7.0.2 the plugin does not work properly, the video image is completely slow and unstable
can be repaired ?
can be repaired ?
geposted Sat 13 Oct 12 @ 5:48 am
scrolltext V2.0 already does this. Right click and enable/disable message. ;-)
P.S. Upgraded to version VDJ 7.2 and not having any problems.
geposted Sat 13 Oct 12 @ 7:42 am
ErikVeejay wrote :
Hi SBDJ
can be repaired ?
can be repaired ?
I'm sorry, the version of virtual dj is 7.2 x Mac
geposted Sun 14 Oct 12 @ 7:04 am
How do I move the scroll to the bottom of the screen? I keep clicking the Move Down button but it doesn't work
geposted Mon 11 Mar 13 @ 4:33 pm
If you're referring to version 1.5.7, the up/down buttons allow you to select which line of text to display.
To move the text up and down, select the "Text" button and use the "Vertical Position" slider.
geposted Mon 11 Mar 13 @ 8:59 pm
Crash :(
geposted Tue 29 Oct 13 @ 9:06 am
Thanks for the helpful information you supplied ;)
geposted Tue 29 Oct 13 @ 11:55 am
Hi all,
This is my favourite plug in of them all and gets most use.
I recently changed my pc and downloaded the plugin V2 from the download centre but it appears to be the old version with the 'right click' edit box, rather than a more recent version i have been using for the past few months where there are tabs within the plugin for the different features ...
is there a different download link available for the newer version ?
thanks for any help !
NIKB-DJ
NIKB-DJ
geposted Mon 13 Jan 14 @ 6:20 am
Tab version = old version = scrolltext.html" target="_blank" rel="nofollow">http://www.virtualdj.com/addons/4560/SBDJ_scrolltext.html
Right click version = new version = scrolltext_v2.html" target="_blank" rel="nofollow">http://www.virtualdj.com/addons/14744/SBDJ_scrolltext_v2.html
Some people have had issues with the newer version though. An improved cross-platform one is still in the works though.
geposted Mon 13 Jan 14 @ 8:17 am
ah, thats great, many thanks
so what i thought was the newer version is actually the old one. It is much more stable. I tend to get a windows crash with the right click version as the pop up window will not always close after editing the text.
i'm off to download it !
NIKB-DJ
NIKB-DJ
geposted Mon 13 Jan 14 @ 10:57 am
That happens with some popup windows in VDJ under certain circumstances - it's often caused by Aero.
geposted Mon 13 Jan 14 @ 11:09 am
Hi,
have you planned an update for support macro in the mac version of the effect or there are limitations from the os x?
geposted Tue 14 Jan 14 @ 6:57 am
Hey,
have an Problem with SBDJ scrolltext and SBDJ Countdown
both effect do not work since 3 Months
on an old Image it works fine but after some updates both are dead
DirectX9 reinstalled...
C++ 2005,2008,2010 checked
geposted Thu 16 Jan 14 @ 7:32 am
When you say they don't work what do you mean?
geposted Thu 16 Jan 14 @ 8:05 am
if i click on it
it looks like that its not there no information of the plugin
no buttons, nothing
no buttons, nothing
geposted Thu 16 Jan 14 @ 8:09 am
No information at all = plugin failed to load = runtime requirement missing usually.
Working OK here on an up-to-date 8.1 x64 machine.
If you're still having trouble then I can try reuploading scrolltext rebuilt with my current compiler version.
geposted Thu 16 Jan 14 @ 10:05 am
what runtimes i should try to reinstall..
i reinstalled
c++ 2005 (x86)
c++ 2008 (x64)
c++ 2010 (x64)
dx9c
more runtimes need???
there is one thing i do not understand...only two effekts do not work
wihich runtime did they have in common...
i reinstalled
c++ 2005 (x86)
c++ 2008 (x64)
c++ 2010 (x64)
dx9c
geposted Thu 16 Jan 14 @ 10:22 am
The only library I can see that is needed by the current scrolltext build is d3dx9_42.dll.
geposted Thu 16 Jan 14 @ 11:36 am
Could be nothing but two runtimes are at 64 and 2005 your showing as 86, so basically you have 2 @ 64 and another at 32, as I said may be something or nothing or just a typo.
geposted Thu 16 Jan 14 @ 11:46 am
