Do i neeed a mapper for my DN-S5000?or there is something else that i need to install, becuse i can't do backward and i can't select a cue with the turntable , can anybody help me(sorry for my english).
geposted Fri 04 Jul 08 @ 12:56 am
The S-5000 doesn't use MIDI, so your only option is to use Timecode CD's.
geposted Fri 04 Jul 08 @ 3:47 am
I'm actually using the time code cd and i use m-audio fast track pro sound card ,it could be the problem ?
geposted Fri 04 Jul 08 @ 10:54 am
M-audio fasttrak don't work... you need 2 stereo inputs and 2 stereo outputs and ASIO compatible soundcard.
geposted Mon 14 Jul 08 @ 9:02 pm
