According to the product information page there is no difference in the software, but from what I've been reading on the forums here there seems to be slight disparity between the two programs. Can anyone give me the real dirt?
geposted Fri 04 Jul 08 @ 4:23 pm
One says Virtual DJ, and the other one says Numark Cue. It is the same. This has been discussed so many times, so if you do a search, you will find more info than you will need.
geposted Fri 04 Jul 08 @ 4:33 pm
thank you! I'll assume to look under general discussion?
geposted Fri 04 Jul 08 @ 5:06 pm
Cue is basicaly Virtual DJ distributed in store by Numark.
Best Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Skype : NumarkSi
Best Regards
Simon Bangs
Skype : NumarkSi
geposted Fri 04 Jul 08 @ 6:31 pm
Try here.
geposted Fri 04 Jul 08 @ 8:11 pm
If you had to choose I would go with VDJ over Cue.
New releases always come out on the VDJ brand before Numark gets them.
geposted Sun 06 Jul 08 @ 12:22 am
Some time there are delays this is true but , only because we like to test them fully before releasing it to ensure best customer experiance.
geposted Sun 06 Jul 08 @ 7:34 am
That is not always true..I believe it was v5r1 that CUE users received before VDJ users.
geposted Sun 06 Jul 08 @ 9:02 am
Maybe, but recently I have been noticing a lot of CUE users have been getting the shaft with updates. This would royally piss me off if I was a CUE user.
geposted Mon 07 Jul 08 @ 9:36 am
I am a CUE and a VDJ user..both programs work just fine on both of my machines.
geposted Mon 07 Jul 08 @ 9:39 am
^ ehh im not totally pissed off but a little jealous ;)
and update for VV? :(
Numark decides when they want to release VV upgrades, but should be soon I hope.. :)
geposted Mon 07 Jul 08 @ 10:26 am
Be aware that CUE does not support the Denon HC-4500 anymore...Other than that, they're pretty much the same software.
I had to purchase VDJ in order to use my HC4500.
ap
geposted Mon 07 Jul 08 @ 2:19 pm
ap
ap
FYI that was acidentaly left by the VDJ develpment team it was ment to be in 5.1 and will be resolved shortly.
geposted Mon 07 Jul 08 @ 3:18 pm
