Hi all.
Is there anyway of stopping VJ from adjusting the gains when I load a track up?
I use an external mixer and prefer to adjust the gains from there.
Thanks
Dj jon
Thanks
Dj jon
geposted Sat 05 Jul 08 @ 9:21 pm
Go to Configure on the skin
Then:Options
Then: Auto gain ( disable)
Then:Options
geposted Sun 06 Jul 08 @ 6:05 am
hmmmm
That doesn't help. As soon as I load a new track, VDJ adjusts the gains. Which is a bit annoying as it changes the volume so I either need to readjust it, or turn up / down the gains on the external mixer.
geposted Tue 08 Jul 08 @ 7:40 am
djjon76 wrote :
Hi all.
Dj jon
Dj jon
Do you mean first time ever you play a track? VDJ will do that then because volume is part of analyze, but just wait to press play until the track is fully loaded.
After this first time, it wont ever happen again
(if you do have auto gain disabled in options)
geposted Tue 08 Jul 08 @ 8:18 am
