Hi, everybody
I was reading the 5.1 user guide, and did not found how to do it. Before this post, tried VDJpedia and there's nothing.
I tried a keyboard shortcut, and did it (loading an audio track on deck, found the video on browser, selecting the video and using the shortucut).
But it don't works. The icon of the audio track don't changes. After this, the audio track doesn't load the entire waveform on deck graphic.
My note aspects: centrino duo 1.75 processor, ram 2Mb, graphics Nvidia 256M (no integrated).
Thanks.
Thanks.
geposted Sun 06 Jul 08 @ 10:03 pm
After 1 day, 26 views and no answers, I'm wondering....
Did I the 1 million dollars question? Or...
Does anyone really understoods what I wanna do? Or...
May I try In portuguese? ;)
geposted Mon 07 Jul 08 @ 9:31 pm
Yeah, I found it!
Now I got the answer, I can't believe I did that question... and I can't believe nobody gaves me an answer, too....
Got to config > video and check "link video when dropped on preview window"
Using the full video skin, load one audio file to a deck. Then, browse to the video file you wanna link to that audio file, drag-and-drop the video to the video preview window of the deck you loaded the audio file.
Now, each time you load that audio file, the respective linked video will run in loop, while the audio is running.
To desassociate, browse the audio file (the icon has now one "L" indicating it's a linked video track), select the file, right-click and select "remove video link"
That's It...
That's It...
geposted Thu 10 Jul 08 @ 6:32 pm
Awesome job..
I've been meaning to try this out but havnt had the time.. or needed too yet..
good description of how to do it.!
geposted Fri 11 Jul 08 @ 10:13 am
Good job. There are so many features that we don't use and we should. This is one of them...
geposted Fri 11 Jul 08 @ 6:36 pm
