Hi I keep losing my Database as in the BPM & my coments;-( Is there a way NOT to lose it as it does take up a lifetime to replace. It is like the VDJ has no memory. Thank you in Advance, Kim
geposted Mon 07 Jul 08 @ 9:31 am
Can you be more spesific?
Do you have external drive? Network drive?
Your bpm and comments should not be lost, but it CAN be overwritten, if you have IDtag read enabled for comments in VDJ browser settings.
If you write your own comments inside VDJ, turn off the Read Comments for IDtags in the browser setting.
As for BPM, VDJ will always make its own BPM, as the software needs to. To know where the beats are, phases, volume and gain, and so on.
geposted Mon 07 Jul 08 @ 10:30 am
I have an EXTERNAL HDrive with all my Videos/MP3s. Most Times I use My Own lap top But rare times I use A clubs one. I add my own comments (infact it's All my info - except the beats which are VDJ's). I always click FIX in the browser after I alter a comment. I have disabled the read comments. Anything else I should do with the new info I have given you? Thank You;-)
geposted Mon 07 Jul 08 @ 11:32 am
Hum thats the only part I reacted to.. Why?
I think you shouldn't use that fix feature too often, or at all, unless you have a huge problem with the database.
If "read comments" for id tags is turned off, your comments should stay fine.
I think it might be the fix you press each time, that turns the database back to an "earlier stage" or something
geposted Mon 07 Jul 08 @ 12:25 pm
