Allthough its a very good feature which i use quite alot, i would like an option (maybe a keyboard shortcut) to disable the needle droping for timecoded vinyl so i can just use the saved cues without having to put the needle on and then re-cue the track
geposted Sun 09 Jan 05 @ 9:53 pm
Take my vote to this.
geposted Mon 10 Jan 05 @ 1:53 am
I'm not 100% sure, but you can try this out for me, and others...
Choose "CD MODE", instead of "VINYL" at timecode setup
I think that will disable needle-drop, but as I said, not 100% sure... if it works on vinyl
geposted Mon 10 Jan 05 @ 6:48 pm
just tried it but no luck. needle dropping still working.
I understand the difference between the 33 and 45 mode but whats the difference between the cd mode and 33 mode? just curious
PJay
PJay
geposted Tue 11 Jan 05 @ 6:23 pm
strange...
the difference should be that in cd-mode, needle-drop is disabled, as this would not be good for cd timecode use...
geposted Wed 12 Jan 05 @ 6:32 pm
i thought that it sort of works with cd's. When you set a cue on the cd player and play it from a specific point. the song jumps to that position when played? i could be wrong
geposted Wed 12 Jan 05 @ 6:45 pm
my bad :)
thats true...
Its the anti-skip feature that is disabled in cd-mode, so that you can use loop buttons
sorry.... :)
thats true...
sorry.... :)
geposted Wed 12 Jan 05 @ 7:02 pm
ask for it as a new feature, in new feature forum...
the dev team might add a feature to turn needle-drop off :)
geposted Wed 12 Jan 05 @ 7:03 pm
