Forum: Old versions
Topic: Master tempo in timecode mode?
Is this a bug or by design? I would think in time code mode for cds master tempo would be applied but not in turntable mode.
When using the time coded cd, seems changing the pitch on the software is the only way to use it currently. If you change the pitch on the CD player it will only pitch.
So i was wondering if this was a bug or by design.
geposted Sun 09 Jan 05 @ 11:54 pm
I'm with you on this Jason. Tempo/Master tempo/Key lock/time stretch (whatever you like to call it) is essential. Almost defeats the purpose of using a hardware controller. It's meant to emulate "whatever you're familiar with", and I'm familiar with tempo adjustment.
Hopefully we'll see this bug fixed, or feature updated soooooon. :-)
Otherwise, the DAC-2 will work, won't it? That will allow time stretch mixing?
for the moment time stretch is very bad ...Pionner CDS , denon or similar .and is bad too in BPM . VDJ or PCDJ .
Yes fix the algorithm first.
So we've established the time stretch option is a bit suspect.
Any chance this is fixable? If so, is it a priority? I hope it can be fixed soon.
