Hey guys!
I have dj control mp3 and virtual dj v3.4.1.and i have some issues about the knobs on my mixpanel...
If i startup the program, i have to turn all the knobs(also faders) from min to max to have the result of quality that i want else
the bass, medium and treble aren't working proper...no big deal if i have to this 1 time but...
I play a song on deck a and a second song is mixed on deck b.
When then i mix a song again from deck a, i have to turn on the knobs again form min to max on deck a else
the bass, medium and treble aren't working proper...???
So it can't be that i have always to turn on the knobs from min to max by each song that i want to mix to have proper working
bass, treble and medium!!!???
Is this a problem of drivers or?
Please help me out :)
Many gr
Many gr
geposted Thu 10 Jul 08 @ 10:28 am
Hey ! thats a good observation......the development team must change that...feature to be at our reach)
BuT ! yes that issue can be solve using the registry or and modifying the xml on thew skin..!
if you have a little of knowledge of both !...just view the codes and change it !..Codes and setting that up to skin type
on the registry you can use a registry editor on the external tools downooad from the virtual dj page
i hope this this can help!....
Do this :Get the registry tool and get the eq pluging and set the registry to don clear effect...........thas easy and the best way
NOW..........there is few other option tools.......
1..Get EQ plugins on sound effect downloads
2..use your sound card software settings to use the equilizer (this i use a lot) keep same setting for all audio..at startup
3...Search for a eq .channels software on google
geposted Thu 10 Jul 08 @ 5:10 pm
