hi,
there are, how can I do to use midi funcions with mybook pro and Dac-3.
thanks a lot.
thanks a lot.
geposted Thu 10 Jul 08 @ 4:24 pm
Go into your settings and select the Remote tab. Click on the picture of the DAC 3. A drop down menu will appear, then select activate. I use VDJ Pro version 5.07, not sure if it's the same on 5.08 Hope this helps.
geposted Fri 11 Jul 08 @ 8:44 pm
