Which one offers more? Which is best? Which has more songs? Which works better with VDJ?n I have noticed that in VDJ pro on the side theres a thing that says napster, what do you do if you have rhapsody?
geposted Fri 11 Jul 08 @ 6:48 pm
I'm not sure one's really better than the other, though the Napster tracks have better tags. I use both because each has tracks the other doesn't, both play fine in VDJ. And I wouldn't worry about the Napster thing in the old VDJ browser, it doesn't work anyway;^]
geposted Sat 12 Jul 08 @ 6:41 am
scribe if your in the US check this out www.VenueVJ.com if your not in the US don't bother, it's only limited to them just now
geposted Sat 12 Jul 08 @ 7:13 am
