I am interested in purchasing the DMC2 and after trying it out at a local retailer..I noticed that it has no control over the gains,treble,mid and bass controls using the FULL CUE/ MIXTURE skin.Does this mapper add anything that might control these? Just curious before I purchase.I have control now using the Total Control.If it doesnt handle any of these controls I assume I will have to use my Numark cm100 mixer?
I am trying to get my mixer,dmx controller and possibly the DMC2 all in my case instead of branching out with equipment.. cleaning up if you will:)
Thanks
Thanks
geposted Fri 11 Jul 08 @ 7:45 pm
Hi there the DMC2 is meant for use in a racked setup , idealy with a cm2000 usb mixer.
The total control is designed as a compact all purpose controller not needing a mixer.
The mapper can alter the functions of the buttons but it makes more sense if you want these functions on a controler to use a tabletop one such as the Total Control.
Otherwise use a rack mixer with a soundcard (or one with a with usb link ie cm200) and the dmc2.
Best Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Skype : NumarkSi
Best Regards
Simon Bangs
Skype : NumarkSi
geposted Sat 12 Jul 08 @ 12:06 pm
The custom mapper has a mixer mode that allows gain, bass, treble, etc. to be adjusted directly from the DMC-2, but ideally you should use the DMC-2 with a proper rack mount DJ mixer.
geposted Sat 12 Jul 08 @ 1:12 pm
Thanks guys....Its good to know that the mapper can do it.
geposted Sun 13 Jul 08 @ 9:19 am
