Scanned through the forums. Can only find that the sunlite dmx controller is supported.
Can anyone confirm if this Enttec model, see link below, is supported with VDJ 5.1?
http://www.enttec.com/index.php?main_menu=Products&prod=70304&show=description&name=dmxusbpro
Freek
Freek
geposted Mon 14 Jul 08 @ 2:28 am
Only the Sunlite usb -> dmx dongle is suported. See here for more information
Ewout
Ewout
geposted Mon 14 Jul 08 @ 11:20 am
for some reason Atomix decided to use Sunlites SIUDI protocol..
The Enttec dongle will not work with VDJ but DOES work with Freestyler (which I think you would be alot happier with)..
geposted Mon 14 Jul 08 @ 12:24 pm
My goal is to have some simple disco lights triggered (DMX controlled) on the beat by VDJ and stroboscope (not via inbuild mic's).
I think the VDJ implementation is suffiecient for that.
Is it the Sunlite SIUDI6 USB - DMX that will do the job?
If yes, the SIUDI6 will then work with VDJ and also Freestyler, correct???
If yes I will buy it from dmxsoft. http://www.dmxsoft.com/main.php?cat_pro=5 They offer it at $109 and if you wait till happy hour there is 15% off the price.
Remark: Within virtual DJ the controller should be named Sunlite SUIDI 6 and not DMX, since this implies it's supports all kinds of DMX controllers which is not the case.
freek
freek
geposted Tue 15 Jul 08 @ 4:00 am
