I've downloaded 5.1. Works good except while it's up and running, I can't access the 'start tool bar' which is normally hidden. When I go down to it, it flickers and the mouse pointer jumps to the top of the program. Anybody know how to fix this? I don't have this problem using VDJ 5.0 ver. 6.
Thanks,
Ronnie
Thanks,
Ronnie
geposted Mon 14 Jul 08 @ 9:49 pm
sounds like your using vista, if you are what ever skin your using just reduce it from full skin don't minimise it, then that should cure your problem... hopefully anyway
geposted Mon 14 Jul 08 @ 10:11 pm
