i now have 3.2 i wonted to no should i upgrade to 5.0 would it be a better thing for me or should i just keep 3.2
i only dj with the mk2 so i would buy the new one for 5.0 ..idk i have a party in two days and im just looking for new features
geposted Wed 16 Jul 08 @ 8:16 pm
3.4 is your best bet!!
geposted Wed 16 Jul 08 @ 8:26 pm
Wait till after the gig and then try 5.1 VDJ, it's a free download for you anyway. I say after because a:] it's not much time to run stability tests and b:] switching from 3.2 you may be overwhelmed by all the features you've missed at first few runs. The mk2 should run without problems on 5.1, but the RMX is still a mighty fine upgrade. Just beware, the RMX will only work with VDJ 5.0r7 and up;^]
geposted Wed 16 Jul 08 @ 8:47 pm
Yes if u only use the mk2 n have a little time to test on V5.1!
geposted Thu 17 Jul 08 @ 7:11 am
thank you guys for all the info
geposted Thu 17 Jul 08 @ 8:29 am
