Hello, I'm new to DJing and was looking for a way to record my mix onto the computer so I can then burn it onto a cd. Is anyone out there familiar with how I can save my mix with vdj?
geposted Wed 16 Jul 08 @ 9:07 pm
What version of VDJ are you using?
geposted Wed 16 Jul 08 @ 9:27 pm
I believe you must have Pro to record, correct me if I'm wrong though anyone.
geposted Wed 16 Jul 08 @ 9:52 pm
Hi, I think I have Atomix version 5. How can I verify that?
Thanks in advance!
Thanks in advance!
geposted Wed 16 Jul 08 @ 9:55 pm
I'm currently using VDJ Pro 5.0.7 trial and you are able to record your mixes with it. If you are using the "full" skin it's the tab to the right of the "effects" tab. It says "Record."
geposted Wed 16 Jul 08 @ 11:05 pm
Then select record, and mp3, and the file name and destination, hit record and go to town.... ;-)
geposted Thu 17 Jul 08 @ 8:37 am
In my humble, I think the best way to record the mix is to DAT & then back to the PC, second best is straight to a second PC using software like Sonar, Pro Tools, Vegas, or Audacity if you need a free program;^]
geposted Thu 17 Jul 08 @ 8:55 am
