Is there a way to temporarily remove video effects from the list. For instance I usually dont use camera, karaoke, etc but I need them there for when I do. I think I can rename the .dll to .xxx or something but is there a better way?
geposted Thu 17 Jul 08 @ 4:12 pm
I guess it's not possible.
Why did you ask it?
If you don't need an effect, I think the simpler thing you should do is not to use it
Why did you ask it?
geposted Thu 17 Jul 08 @ 4:50 pm
why not make a back up folder of all the effects that you need and use and simply copy them over to the plug in file when you need them, so it doesn't matter how many times you delete a particular plug in you have a ready available source with you.
geposted Thu 17 Jul 08 @ 6:12 pm
Cool, thanks. The reason I ask is that I use a DJM700 mixer to control which doesnt have a lot of buttons so I select video effects using a fader and its easier when theres just a few to select from.
geposted Thu 17 Jul 08 @ 10:38 pm
no probs...
geposted Fri 18 Jul 08 @ 5:12 am
