Hi all,
I am using Itunes to organise my library..
Now i have a problem: I have erased all comment fields in Itunes, and with a ID3tag software..
But in Virtual DJ the tagging is still present.
I can't find where Virtual DJ get the comments field from.
I tried to uninstall Virtual DJ completely erase all directories and registry entries.
But when i reinstall Virtual DJ the old comments are still there.
I have even tried to re-read the tags, but still the same ..
In Itune, Traktor DJ and TORQ the comment fields is empty, but in Virtual DJ the comment field is still filled with its original stuff.
I am using the comment field as my rating indicator (like Itunes) for faster preferred songs findings in my play list.
Please can some one help
Regards
Regards
geposted Fri 18 Jul 08 @ 6:40 am
which ID3 tag software are you using..
geposted Fri 18 Jul 08 @ 10:13 am
Am using id3tag version 3.3
geposted Fri 18 Jul 08 @ 10:22 am
Virtual DJ stores its database file in your "My Documents/VirtualDJ" folder. Delete the file "VirtualDJ Database v5.xml" and it'll be recreated on next startup. However, you will lose all analysis information this way. If you have Microsoft Excel or similar programs, you can edit the xml file to remove comments.
geposted Fri 18 Jul 08 @ 2:25 pm
