I have a problem....I noticed wen ever I use the flanger effect...and the crossfader to mix. I get a static noice on the music...like if am crumbleling up a bag....now this is just on my computer not using a mixer or nothing like that...just with the mouse and vdj. anyways i started noticeing wen i started recording...sounds bad.....so yesterday i dj a party with the rmx..and damn u could hear it bad on the jbl's..nasty noice. specialy when using the crossfader....even if i dont use the effect u still hear it....and its not the mixer cause it does it with just my lap top....never done it b 4 till now....??? any suggestions?
geposted Sun 20 Jul 08 @ 3:00 pm
Try adjusting your latency, in the config menu, and over clock and safe mode...some times different combinations work better on some machines...
geposted Sun 20 Jul 08 @ 3:32 pm
hey
well i asked here but i garra no answer
i search some cds for scratch like dmc vinyl who used the djs to make scratch (some diferent typ for sound effect in this cds )
thanks
thanks
geposted Sun 20 Jul 08 @ 4:34 pm
HELL YEA THAX TEAREMUP.... IT WORKED....BUT ALL I DID WAS TAKE IT OFF AUTO~
geposted Mon 21 Jul 08 @ 12:12 am
