So I was planing to build a pc, but right now I'm not doing any gigs because the pc which I own has problem. I could take my time and build a pc but not do any gigs or i could just buy this pc and build one later on..........here are the specs...in best buy...
HP - Pavilion Elite TV Desktop with Intel® Core™2 Quad Processor Q6700
Warranty Terms - Parts
1 year limited
Warranty Terms - Labor
1 year limited
Product Height
15.5"
Product Width
7"
Product Weight
24.25 lbs.
Product Depth
16.6"
Processor Brand
Intel�
Processor
Intel� Core(TM)2 Quad
Processor Speed
2.66GHz
System Bus
1066MHz
Cache Memory
8MB at die Level 2
System Memory (RAM)
6GB
System Memory (RAM) Expandable To
8GB
Type of Memory (RAM)
PC2-6400 DDR2 SDRAM
Hard Drive Type
Serial ATA (7200 rpm)
Hard Drive Size
750GB
Graphics
NVIDIA GeForce 9500 GS
Video Memory
512MB (dedicated); up to 2303MB total available graphics memory
Personal Video Recorder (PVR)
Yes
TV Tuner
Yes
MPEG
Yes
Audio
High-definition (8-speaker configurable)
Built-in Webcam
No
Modem
56 Kbps*
*Capable of receiving 56 Kbps downloads. However, current regulations limit download speed to 53 Kbps.
Network Card
Built-in high-speed 10/100/1000Base-T Ethernet LAN (RJ-45 connector)
Wireless Networking
Built-in high-speed wireless LAN (802.11b/g/n)
Recordable DVD Drive
Yes, double-layer DVD�RW/CD-RW
Recordable DVD Drive Speeds
8x DVD+R DL; 8x DVD-R DL; 16x8x16 DVD+RW; 16x6x16 DVD-RW; 5x DVD-RAM; 40x32x40 CD-RW
Direct-Disc Labeling
Yes
Digital Media Reader or Slots
Yes, digital media card reader
Total Expansion Bays
External: 1 (3.5"), 2 (5.25"), 1 Pocket Media Drive; Internal: 2 (3.5")
Available Expansion Bays
External: 1 (5.25"), 1 (3.5"), 1 Pocket Media Drive; Internal: 1 (3.5")
Total Expansion Slots
1 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2
Available Expansion Slots
None
USB 2.0 Ports
6 USB 2.0 (2 front, 4 rear)
IEEE 1394 Ports
2 (1 front, 1 rear)
S-Video Outputs
1
Additional Audio/Video Connectors
S-video input, composite video input, HDMI output, DVI output, digital audio input, digital audio output, rear speaker output, side speaker output, center (subwoofer) output
Serial Ports
None
Parallel Ports
None
Game Ports
None
Keyboard Description
Multimedia
Other Control Devices (mouse, etc.)
HP optical mouse, HP Media Center remote
Operating System
Windows Vista Home Premium 64-bit with SP1
Software Included
muvee autoProducer; CyberLink DVD Suite Deluxe; Microsoft Works 9; Adobe Reader 8.0 and more
$1,029.99.......BESTBUY.......will it work fine with virtual dj............its 64-bit so does that mean it wont work with denon hc4500, hercules mk2, and all MIDI stuff or what?
http://www.bestbuy.com/site/olspage.jsp?skuId=8891737&type=product&id=1212192194712
1 year limited
1 year limited
Product Height
15.5"
Product Width
7"
Product Weight
24.25 lbs.
Product Depth
16.6"
Processor Brand
Intel�
Processor
Processor Speed
2.66GHz
System Bus
1066MHz
Cache Memory
8MB at die Level 2
System Memory (RAM)
6GB
8GB
PC2-6400 DDR2 SDRAM
Hard Drive Type
Hard Drive Size
750GB
Graphics
Video Memory
Yes
TV Tuner
Yes
MPEG
Yes
Audio
Built-in Webcam
No
Modem
56 Kbps*
Network Card
Wireless Networking
Yes
None
USB 2.0 Ports
IEEE 1394 Ports
2 (1 front, 1 rear)
S-Video Outputs
1
Serial Ports
None
Parallel Ports
None
Game Ports
None
Multimedia
Operating System
Software Included
geposted Wed 23 Jul 08 @ 1:35 pm
If you like building your own PC, then go to www.MicroCenter.com the prices are cheaper and they sell cases, power supplys, processors etc.
Or Check out www.TigerDirect.com over 1 g for that computer is to much...
geposted Wed 23 Jul 08 @ 8:27 pm
