I have two hard drives that are 500gb each. I just purchased a 1TB hard drive. I plan on merging the MP3's from both 500gb drives to the 1tb drive. I know currently each drive has it's own database. After I merge the two dirve will VDJ/CUE still read all my cue points originally from both drives? If not is there anyway to merge the databases also.
Thanks
Thanks
geposted Fri 25 Jul 08 @ 2:04 am
ray, I think if you use a text editor to merge the 2 local .xml files, it should work. Just make sure you edit the paths to be the same.....if they were on different structures in the old drives
geposted Mon 28 Jul 08 @ 9:00 am
