I recently upgraded to iTunes 7.7 on my white Macbook 2.2ghz. Now all my id3 tags are messed up. Part of my music library is in iTunes and part of it is a generic folder. The id3 tags are fine for all the songs in the generic folder. However, every song that is in iTunes has the id3 tags messed up.
I can search for the song and the song title is displayed, but other info like artist, disc, track number etc. is now gone. This additional info used to be displayed in the browser window along with the song title. However, when I right click on the song and select file infos, the window that pops up has all the id3 tag info below the corresponding box with the circled arrow next to it. I can click on that circled arrow button to add the info. This is very time consuming and I would prefer not to have to do that for my entire iTunes library.
The current version of id3 tags is v2.2. I have tried changing to older versions (v1.0, v1.1) and the newest version (v2.4) and have re-scanned my iTunes folder with no luck. I have also deleted the database file and re-scanned the hard drive to rebuild the database. This did not help either.
Any one else having this problem? Any suggestions on how to fix?
geposted Sat 26 Jul 08 @ 1:04 am
Anyone have thoughts or ideas?
geposted Mon 28 Jul 08 @ 8:57 am
only way i've found is to turn them into mp4a files then the tag data comes back.
geposted Mon 28 Jul 08 @ 10:36 am
I will do that if that is the only fix.
Is it known whether this is an iTunes issue or a VV issue or something else?
geposted Mon 28 Jul 08 @ 12:15 pm
ive read of numerous post regarding tag issues with itunes 7.7
http://discussions.apple.com/search.jspa?threadID=&q=tag+problems&objID=f789&dateRange=last90days&userID=&numResults=15&rankBy=10001
geposted Tue 29 Jul 08 @ 1:29 pm
DJ Cyder,
What software did you use to convert files from MP3 to M4A?
geposted Wed 30 Jul 08 @ 1:18 am
I used itunes, it took several weeks to convert my collection.
geposted Wed 30 Jul 08 @ 7:17 am
I did a test and converted a couple files to AAC/m4a, and now I am getting most of my tag information. I have info in the "genre" field in iTunes and that data is not coming through. Title, artist, album and BPM info is there but no genre. Even if you right click and go to file infos the data is not there to add.
Help! This is really getting frustrating.
While on this topic. Are there any better audio management applications that integrate with VV and are comparable with iTunes?
geposted Thu 31 Jul 08 @ 1:26 am
Me too. At first I thought it was due to the number in the title (ex): ' 03Kissing Whales', but then even after I removed the trk# in iTunes, still missing tags. I also tried the "convert to" work around, but it didn't work for me either.
geposted Thu 31 Jul 08 @ 6:57 pm
itunes 7.7.1 is out, try that.
geposted Thu 31 Jul 08 @ 11:13 pm
I just downloaded 7.7.1. It didn't help.
geposted Thu 31 Jul 08 @ 11:52 pm
I trashed the com.atomix prefs file. Although I had to do the serial# again, I re-read most of my iTunes tags with the exception of aiff(artsit, and bpm), and some CD genres.
I had also trashed the Vdj local database .xml file, but I really don't know if that affected the results.
geposted Fri 01 Aug 08 @ 11:07 pm
djkenelson,
Thanks for the reminder about the .plist file. I deleted the .plist file and the VV database and re-scanned my external hard drive and it appears everything is back to normal.
In fact, I remember reading a post that "skyfxl" responded when you have weird problems like this it is a good idea to delete the .plist file and start fresh again.
Thanks again djkenelson!!
geposted Fri 01 Aug 08 @ 11:53 pm
You're quite welcome!! I wish I had read the "skyfxl" post before I did all the stuff I did. I even went back to the LE version this morning. I sure wish we had a better instruction manual. This will be for another post, but now that I got the basic idea of how to work Vdj, I really need to get help on the more intricate operations such as video etc.....
BTW, when you deleted the database, did you find it again? I cannot find it anywhere.
geposted Sat 02 Aug 08 @ 1:17 am
Howdy glad you found my info useful, the plist and databases will be rebuilt on next run if this fails do a reinstall to force this.
If you need some help feel free to PM me.
Best Regards
Simon Bangs
Computer DJ/VJ product Specialist.
Numark Alesis Europe
Best Regards
Simon Bangs
geposted Sat 02 Aug 08 @ 4:05 pm
It seems that this is to do with an obscure fault with itunes 7.7 because it has affected several softwares strangely perhaps they have changed the API.
I will check this out further and get back to you.
Best Regards
Simon Bangs
geposted Sat 02 Aug 08 @ 4:08 pm
skyfxl,
Thanks to you for your great resources and information. I just wish I would have remembered the .plist file trick 3 weeks ago.
Looks like you are investigating this further. I know you will post your findings once you have them.
geposted Mon 04 Aug 08 @ 4:32 pm
