Does anyone have an easy way to adjust the base from the skins ?
the control I find for doing this is quite small to manually adjust easily
Thanks
Thanks
geposted Mon 28 Jul 08 @ 6:21 am
Options:
1/ use an external mixer
2/ use a midi controler
3/ use keyboard shortcuts to set the values and steps you need
4/ find a skin with slider instead of rotary button
5/ modify the skin yourself to suit your need
(or ask some of the nice skin guys on the board for help)
geposted Mon 28 Jul 08 @ 12:23 pm
